Results 1 to 4 of 4
Thread: Coupe help
    Junior Member CobraSnake7's Avatar
    Coupe help
    I am working on an almost done coupe that I am installing a/c in. Can some of you post some pictures of how to mount the condenser, and several pictures on the lines. Thanks, Larry
    All the lines exit towards rear of motor as in bottom pic.
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Quote Originally Posted by CobraSnake7 View Post
    A/C? In the Central Valley? Come on Larry, it only gets to 110 for a few weeks every summer....who needs A/C? Glad to see that you're busy and have stuff to do.
    Take care,
    Ray
    I have a coupe in Clovis with a/c if you want to look at it.
