There is a 2007 Impreza Outback with 40K miles going to auction today at the Portland, OR Copart facility. Lot #26632372.
I believe so.
That is correct.
The only Legacy based Outbacks that could make "single donors" are the '96-'99 models, which are older than (but otherwise similiar to) the stated donors of the '02-'07 Impreza.
Despite my lack of Subie knowledge, that is one fact I was actually aware of! Good to point out for others, for sure.
So your saying if I get a 99 outback sport it would work ?
I found a 99 sport by me, and a good price, hope to check out Sat
Without knowing all the kit details yet, I can't say for certain that anything outside of the stated '02-'07 Impreza based cars *will* make a single donor.
However, I can say that using a '90-99 Legacy based car or an '93-'01 Impreza based car will only have minor challanges. Most of those should be overcomable by a good "backyard mechanic" or even "internet scrounger".
Off the top of my head, some of the minor differences you may see are:
Cable clutches on some early cars.
Different hinges, mirrors, and minor trim and brackets that FFR *MAY* reuse.
Slightly different bolt hole locations on the pedal and column assemblies. (Same shape, just need to redrill)
Instrument cluster will not fit the FFR provided dash panel without some degree of rework or cover-up.
There *may* be a difference in the transmission that requires a different 2WD conversion kit than the one FFR will provide. Commercial kits are available.
I haven't touched on the engine variations, but all will bolt in. Early cars had 1.8 and 2.2 SOHC motors, later cars had 2.5 DOHC and SOHC motors.
