Trying to mount the radiator overflow tank to the X-member. When I line up the brackets on the overflow tank with the corresponding x-members, the tank hangs about three inches below the main tubes. Any else experience this....
Can you share a picture? Running changes in the parts used make it difficult to visualize the problem. My Coupe kit was made in summer of 2010 and the tank fit fine on the x-brace.
Coupe #497 delivered 7/29/10. Engine in on 10/1/10. Pushcart on 10/4/10. First start on 12/01/10. First go-cart on 12/31/10. Finished and on the road as of February 2012.
Coupe Body Buck Plans - My Spray Booth - Painting Lessons Learned
Build site: www.bamacoupe.blogspot.com
Lots of build photos and some observations: http://www.flickr.com/photos/53614858@N05/
Had the same problem so put it some place else also got a 32oz over flow here is a pic65 Coupe 005.JPG65 Coupe 003.JPG
Howdy,
I used a coolant tank from a 2000 Windstar and mounted it to a bracket that I made that bolts to the driver's side head.
Paul
FFR 4859GT 414W (stroked 351W, 4.0" stroke, 4.060" bore). Tremec TKO 5spd. IRS w/3.55 and Torsen diff. 13" dual-piston front disc brakes (Mustang Cxxxra parts), 12" rear disc brakes (Corvette parts). 2003 Mustang Coxxa wheels, 275/40 front, 315/35 rear.
Possibly the only person in the world that is currently building a Spyder GT.
Must be real difficult to get out of your car Stengun with the coolant tank bracket bolted to your head!!! LOL
Bill
