Results 1 to 10 of 10
Thread: Black edge on windshield question...
    Senior Member rj35pj's Avatar
    Marion, IN
    I know this topic has been discussed before on this forum but I can't find it.
    What is used to "paint" the black edge around the windshield???? Once it is dry I plan on using 3M windshield adhesive, will it mark the black border or show through it???
    First Time Builder DARKPT's Avatar
    West Alabama
    windshield primer (black) - 3M Single Step Primer part number 08681
    I got mine from Amazon. I don't recall the brand of adhesive used to install the windshiels, but it dows not show through.
    One item of advice on the windshield primer. It doesn't take a second coat very well, so get it on thick enough in the first coat. Have a BRIGHT light around to check your work.
    Coupe #497 delivered 7/29/10. Engine in on 10/1/10. Pushcart on 10/4/10. First start on 12/01/10. First go-cart on 12/31/10. Finished and on the road as of February 2012.
    Coupe Body Buck Plans - My Spray Booth - Painting Lessons Learned
    Build site: www.bamacoupe.blogspot.com
    Lots of build photos and some observations: http://www.flickr.com/photos/53614858@N05/
    Senior Member CJBergquist's Avatar
    Palo Alto, CA
    I tried the 3M primer and ended up with a big mess. It is 1 step...if you have to touch up anything (second step) it pulls the first pass up, big globs...I couldn't make it work. I removed it, another mess, then used a two part epoxy paint. I used an air brush ($10 Harbor Freight) and paint from the link below. $5 for the black and $10 for the catalyst plus shipping.
    https://shop.mecoa.com/shopdisplayproducts.asp?id=98
    Make sure you clean the glass real well...I used acetone.
    If it's too LOUD....you're too OLD!!
    Build Site >> http://www.flickr.com/photos/51103049@N00/collections/
    FFR#0441CP Complete Coupe kit, IRS, T-5, 392ci 351W, Webers, Delivered 4/29/09
    Marion, IN
    Thank you both for the info.
    Palo Alto, CA
    I just remembered I have photos of both attempts...
    THE BAD
    THE GOOD
    Senior Member willy's Avatar
    Gillette, Wyoming
    I used the 3M single step primer 08682 got it from NAPA had no problem
    Senior Member Fluge's Avatar
    Ontario
    Just so you know...you are not suppose to let it sit too long before installing the glass. I was told to let the glass installer do it right before installation.
    Marc
    It's just A Matter Of Time
    Marc
    FFR Coupe 434, 347ci, Power Brakes, SAI Mod, 3 link rear
    Marion, IN
    Quote Originally Posted by Fluge View Post
    Marc
    Thanks Fluge, but which process were you talking about??
    Tech Support Manager, FFR Tony Zullo's Avatar
    Hi guys we use 3m vinyl and wrap the border looks very uniform and smooth,and it can be any color..
    Tony@ffr
    Ontario
    My understanding is that what you apply to the glass, if you want it to help hold the glass in, must be of the appropriate compound and applied just before installation of the glass so that it cures with the glass epoxy (or whatever you call it) to increase strength. Using any black paint will look good but it won't contribute to the safe installation of the glass.
    You are best to call a glass installer and ask them.
    Marc
    Marc
