Thread: Roadster electrical experts?
    Dec 2012
    Anyone know of someone in the Phoenix, AZ area who can install a donor wiring harness into the Mk4 roadster? I'm contemplating getting the Factory 5 harness system for it's simplicity, but if there is someone in my area who will do it with the donor harnesses I already have for cheaper than purchasing a new one, I'm interested in paying to have it done....
    Jon
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Save your self a ton of work and aggravation. Get a hold of these guys: http://www.wirediet.com They've done hundreds of wire diets and probably have one done just waiting to be shipped. They take yours in trade (I think) or may just diet yours to be sent back.
    Anyway, it's worth talking with them.
    I don't have any connection with them (I have a carb'ed car) but have seen their work.
    Ray
    Mathis, TX
    I used the Ron Francis harness. It is a great system. If you haven't already, you must strip all of the donor stuff (wire diet) before installing from the donor. Looked like a major job beyond my skill and patience, so I left that stuff on the Stang. It's not that hard to install the aftermarket harnesses. The RF has a really good manual and I'm sure the FFR does too. There are lots of threads on using the donor harness. Here is a good one.
    http://thefactoryfiveforum.com/showt...where-to-begin
    Whichever way you go, good luck and have lots of fun.
    Senior Member MPTech's Avatar
    St. Louis, MO
    What's your motor setup? 302 / Mod motor? carb/Fuel Injected?
    I used a Painless Harness (with way too many circuits) and a rebuilt engine harness from Chuck (Mustang Medic on FFCars, don't know if he's on here or not). His harness was great and definitely a good VALUE! Highly recommend.
    Dec 2012
    I will definitely take a look at their site, thanks! I too have a carb motor, so the engine harness is not my concern, it is all the other connections and un-needed junk on the donor harness I got out of the Mustang...what a mess!
    Thanx again,
    Jon
    Super Moderator
    Ray's Avatar
    La Mesa, California
    If you are using a carb'ed motor and no computer, go with the Painless or Ron Francis harness.
    Ray
    What Ray said. Why put that old harness in your car when your not using the engine section. Buy a painless or similar harness.
    Without question, use the FFR/Ron Francis harness for a carbed car.
    Dec 2012
    Sounds unanimous...a no brainer for me now...thanx guys!
    Jon
