Results 1 to 2 of 2
Thread: Coyote torque specs
    Sep 2011
    Coyote torque specs
    FF Tech
    What do you suggest for torque spec for a Coyote engine.
    1. Flywheel to engine, do you use Blue Loctight
    2. Pressure plate to Flywheel
    Factory Five Distributor Hammink Performance's Avatar
    Ommen, The Netherlands
    Hi Dan,
    On our Coyote we used blue loctite on the flywheel bolts, and this is the torque spec we used.
    flywheel to crank bolts 2 stages 177 lbins / 60 degrees
    (it was a long time ago and I did not find a source for the spec I wrote down so it would be nice if someone here could verify what I just wrote)
    (the car has only been racing, and the flywheel never came of so we should be good :-) )
    The clutch we mounted was from centerforce, and it came with specific centerforce specs so I am not sure if they will help you.
    Distributor of Factory Five for Europe
    www.hamminkperformance.com
