![BluePrint Engines](https://www.factoryfive.com/wp-content/uploads/2015/12/BluePrint_Engines_Factory_Five_banner_ad_revised.gif)
The stock double hump oil pan is ideal for the power steering setup. Don't need to change it. Not sure if mounting the compressor down low will work. Not a whole lot of room down low. I would try leaving the serpentine setup that you have now, alone. Just remove the air pump and get a shorter belt. For a neater look you might want to swap the alternator and air compressor. That way the hoses aren't running on both sides of the engine. The air conditioner can usually be ordered with either bracket. I think Breeze makes a driver side alternator bracket.
Don't forget to check out my website for some nice 33 parts at www.replicaparts.com
Thanks Mike
Thanks for the input Mike. I found a March system that puts Alt and A/C up high. A/C is still on Pass. side but it needs to for the unit is on that side in the cockpit. I will check out you site as well.
The frame really gets narrow up front. Here are some pictures of how the Billet Specialties Tru-Trac mounts the compressor. Here is a suggestion. Don't use the FFR supplied a/c lines, way too bulky. Go to the Vintage Air site and look up the Aeroquip lines. They are much smaller and the fittings get installed with a special plier (Vintage Air rents them) therfore no need to have those big ugly crimmped fittings. You can just seem them in the pictures.
Olli
![](http://i34.photobucket.com/albums/d101/ollijo/HotRodAssemblyandKC349009.jpg)
Thanks Olli, That is a nice setup. Thanks for the tip.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
