Unfortunately I forgot to powder coat the adjustable lower control arm sleeve and had to run down to drop them off to the powder coater. I also thought the spindles were already coated but when I put them on I noticed that it was a anti-rust coating on them. So I am having them done as well. Guess I need some better light in my garage.
I also painted the steering column and installed it a couple of days ago. I put a few coats of satin clear, so I hope that will help protect it from scratches.
I installed the steering rack as well. Now it's time to start bending some brake lines. I will probably install them on the outside like some of you guys have. It seems to be much cleaner and it hides them when the body is on.
