![Midwest Classic Insurance](https://thefactoryfiveforum.com/attachment.php?attachmentid=40531&d=1428867682)
That's a new one for me. I suspect the adapter may be machined wrong. I would call FFR on Monday or Tuesday if the are celebrating the holiday.
After talking to FFR and some help from the other forum I made a 1/8" washer to shim the adapter up and it works fine now.
Yes I did. Called IDIDIT. They instructed me to put a 1 or 2 wraps of clear tape, the kind you use for Xmas wrap, around the lower part below the splines. That worked to my surprise.Simple and easy solution.
![Martin's Dent and Collision Shop](https://www.factoryfive.com/wp-content/uploads/2019/02/martins-dent-shop.jpg)
