Thread: New Spec Engine Build...Questions and Tips
    Apex, NC
    Question New Spec Engine Build...Questions and Tips
    Starting down the road of my 2013 build, but I have a few questions.
    First ones are for Jim: Any rule changes that I need to know about before I start? Any changes to specs or opening up some of the standards?
    Second set of questions: What are some of the lessons learned and such in other builds done so far?
    What connectors/bolts are people using now? APR?
    Any other good tips?
    Maybe we can make this thread a sticky for others too.
    2012 NASA-SE FFR Champion
    2011 NASA-SE FFR Champion
    Race page - http://www.mh-motorsports.com/race.shtml
    Team Facebook page - http://www.facebook.com/pages/MH-Mot...s/264814350042
    Apex, NC
    I am going to start copying some of the other threads in here so all of the engine update info is in one place.
    Senior Member tcoon's Avatar
    Angwin, CA
    The biggest problem seen here on the west coast has been with ignition. The new system stresses the stock ignition to the max, and we have seen high speed misses which were hard to sort out. Basically we all replaced the entire engine compartment from firewall forward (dizzy, coil, plugs, wires, even an entire wiring harness!). Also carefully check your computer...I went through three before I found one that gave the advertised horsepower(others had inadequate spark advance at high rpm)...remember these computers are twenty years old!. In the case of Robert Walter failure of a "new" distributor was even found. Your entire engine support system must be in tip top shape.
    Coyote powered Daytona Coupe Competition Racecar #21
    Challenge series #21
    FFR 33 Hot Rod
    2009 3rd place NorCal series
    2010 3rd place West Coast series
    2011 2nd place NorCal, 2nd place West Coast Series, 3rd place WERC class E1
    Angwin, CA
    The other problem I forgot to mention is sound. Both Robert and I have been black flagged for sound...105 db for me and 108 for Robert. As it now stands we are illegal at ALL NorCal tracks! Ouch! (we both live and race in NorCal) Still working on a viable solution.
    FFR 33 Hot Rod
    Apex, NC
    Valid Upper intake answer:
    Quote Originally Posted by jetsbaby View Post
    The NASA new rules state that upper and lower intake is part # TFS-51500003..The picture on the Trick flow website looks the same as the picture..Here is the link..I would have to call TF and see if there is a part # cast into the intake..Thanks
    http://www.trickflow.com/largeimage....t=TFS-51500003
    Apex, NC
    John G's Build and Questions answered by Eddi at TF:
    http://thefactoryfiveforum.com/showt...921-Trick-Flow
    Apex, NC
    So building my final parts list
    other than the T/F package, what other items do I need to add?
    Joliet, IL
    I needed to get a timing chain cover gasket, second TB gasket and a front crank seal so far, more to come probably. I'm just doing a bare bones top end conversion; short block is still in the car, using same timing chain, lifters, water pump, sensors.... so far. I'm in the middle of cleaning the block and should start assembling tomorrow.
    Joe
    FFR Spec Racer
    Apex, NC
    Parts came in yesterday's. I hope to start the build this weekend.
