Thanks Thanks:  2
Likes Likes:  3
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 154
Thread: Wallace18's 33 build
    Well I ran into a snag. I finished up my brake lines. and the next thing in the manual was mount the steering wheel. The adapter slid down on the column easy and I noticed no air gap. Sure enough if I tighten the nut by hand 1/8 turn the whole thing locks up. I can't be sure if it is a bad adapter or column. I just know it won't work with what I got. I am calling FFR today when I get time.
    Senior Member hdnik's Avatar
    Welland, Ontario Canada
    Yer rockn this thing. Looks Great.
    Nick Sebastian - 33 Hot Rod #495
    Factory Five Forums - hdnik
    FFCars - lowntubd
    Build Site/Blog - www.nicks33hotrod.com
    After talking to FFR, I made a 1/8" washer to shim the adapter and all works fine now.
    I will watch for the same issue. Thanks
    FFCars - lowntubd
    I installed the fuse panel and temped in the wire harness. I installed the horns and finished up the steering wheel. I am waiting on my motor and trans mounts. Joe at FFR said maybe next week. I mocked up my radiator, condensor and grill. Then I drilled all the aluminum I could and put 2 coats of lizard skin sound deadner on them. I will add the ceramic heat barrier next. I caught the flu for a few days so it slowed me down some. I got back at it some today.
    Senior Member bil1024's Avatar
    NY
    Looking good!
    Who's fan shroud is that or did you fab it yourself. I have to get one.
    FFCars - lowntubd
    Senior Member maczter's Avatar
    Feb 2013
    Xenia, OH
    Are you putting the deadener on the panels that ill be covered by the carpet, or on the underside of the vehicle?
    FFR HR #530
    Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
    My build blog: http://jacks33hotrod.blogspot.com/
    The shroud I got from Michael Everson. He has some nice stuff on his website. I bought a few tools from him as well. He is a great guy to work with. The lizard skin is on the outside. I am using the sound deadner and ceramic coating. You have to install the deadner first then the ceramic. On the inside I am using a differant material from Eastwood for heat and sound control. I used this method on a 78 Vette I did a resto rod deal on and had great results.
    http://www.replicaparts.com/
    I may be asking the previous question a different way, and if so, I apologize!
    Is there a benefit to using the Lizard Skin on the exterior (both of their products), and then the Eastwood product for the interior. Why not use both Lizard Skin products and then the Eastwood product over the top all on the interior panels of the car? Is there a particular benefit to both coats of the Lizard Skin on the outside, with the Eastwood on the inside? Or, just personal preference?
    I am not challenging you, rather just trying to understand for my own clarification. Thanks!!
    Horseheads, NY
    Thanks Steve, I was actually wondering the same thing....maybe putting the lizard skin on the outside protects the aluminum from the elements?
    Thanks wallace18... I will be ordering one for sure!
    FFCars - lowntubd
    The lizard skin is also like some OEM coverings for body protection. It will help with stones and such. To me it serves no use on the inside. This is where the additional sound proofing made for the inside has it over the lizard skin. I guess one could use the lizard skin inside and out. If you watch the 2 guys garage video of the 33 build you will see them use it on the outside. This is just my way of doing it. It has worked for me on several cars. TEHO.
    I was able to do some work on the A/C part of the 33 the last 2 days. I finished up the grill, Cond, cond lines, fan and radiator work. I made some extra braces for the lines. I installed A/C's for years and I know what vibration can do to aluminum lines. I also installed the bulkhead fittings and evaporator. I used 1/4-20 rivnuts and S/S bolts for the mounting. Hopefully my mounts should be here late Tuesday and I can install the engine and trans. Then I really can start moving along. I am really enjoying this build. I can't remember when I had this much fun building a car.
    After hearing another 33 builder having rad mount problems I decided to mount mine just to see. It fit fine. Looks cool too. I hope to mount engine and trans this week.
    See now that's great news. I heard the same things and was a bit worried... I want to send mine out to be plated. I'll likely mock it up just to make sure all the brackets work and align anyway... But good to know F5 has debugged quite a few things.
    FFCars - lowntubd
    Wallace. Can you take some pics of the brackets from the side?
    FFCars - lowntubd
    Here is a picture of the side. Note how the slots for the grill bolts show out the back . I pulled the grill as far forward as I could. This gave me room to mount without a problem.
    Today was a good day! My motor and trans mounts came in at 11:00. I was able to install the engine, trans and drive shaft. Also I installed the radiator/grill unit as well. I had to trim the drivers side motor mount a little to clear the Electra-Steer unit. Other than that it went in very easy. That 5.0 was made to fit in that chassis well.
    Exeter R.I
    Looks great man, soon you will be driving it, and then the 818 will come
    I was able to finish up the radiator hoses, mock up the carb /air cleaner, install the battery and kill switch. I also am slowly working on the wiring harness. I had to modify it for my application so far. This is so much fun it should be illegal!
    Senior Member esff32's Avatar
    La Verne, Ca
    I thought I was moving along at a decent pace, but man, you are flying. Looks great so far.
    Yer both moving very fast. Congrats to you gents.
    FFCars - lowntubd
    I hooked up my coolant bottle and ran a aluminum line down the frame to the radiator. I also ran an alum. fuel line and mounted my Boyd gas tank. I made a brace for the clutch cable. It is a little crude looking now but works great. When I pull off the firewall for engine turning I will pretty up the braket some. No one will see it, but I know it is there. It really cut down on the flex. I made it out of scrap from a gate opener.
    Aug 2011
    Midland, Texas
    solving the firewall flex this way imho is a no brainer! good job!
    Man wallace you are really moving along!
    I was able to hook up my fuel pump, tank, fuel pressure regulator, fuel filter and carb. I also wired the fuel pump and tank level sender. I hooked up as much exhaust as I could. Rear split exhaust still on B/O. I'll start on my A/C lines and dash wiring while I wait.
    Wallace... Yer a maniac!
    Looks like we are using the same setup... Fuel pump, regulator and boyd tank. Did you use aluminum line from your AN fittings and braided lines or the rubber? I was figuring on using metal myself.
    FFCars - lowntubd
    I used an aluminum line from Summit 3/8". It was very easy to work with. The fellow who gave me the FFR tour told me that is all he uses. He gave me a few tips as well. Heck I am retired and this is like playing golf for me. I love this sort of work. If I am lucky enough to go to heaven some day, I'll build Factory five stuff there.
    Today I installed the trunk top, the back aluminum next to the gas tank and the floors. I had to lay a seat in there and sit in it once. I was happy with how I fit. I am 6'3" and feel comfortable. Here is some shots and you can see the lizard skin on the bottom.
    I made my own dash plate out of 14 ga. aluminum. I copied the FFR panel but added 1 inch all the way around. I did the engine turn finish on my drill press. I also installed some A/C lines today.
  32. Thanks sturigus83 thanked for this post
  33. #72
    Friday I finished up my A/C lines and heater hoses. I mounted the valve inside. Hopefully that will work out OK. Today I worked on the wiring. I have everthing but the lights and dash gauges working now. My wheels are here and I am going to put on the tires this week and hopefully put the body on for the first time on Friday. Stay tooned for more action.
  34. #73
    What wheels and sizes did you go with.
    FFCars - lowntubd
  35. #74
    I got Summit 17x8- 5.25"BS front and 18x9- 6.0" BS rear Legend 5 wheels. I was able to get them quick. My original FFR wheels are backordered. So I canceled out of them. I needed to get the chassis rolling. I need my lift for a clutch job on another car.
  36. #75
    It Lives!!!! After a few days of fixings oil, coolant and brake fluid leaks I was able to drive the gocart around to the neighbors. My wife helped bleed the brakes so she called shotgun. It runs perfect. Lots of power. Breaks the wheels loose at 1/4 throttle. Take a look at my high tech gas pedal cable setup. It is 40 days since I picked it up at Wareham. I have done all the work myself so far. This is a great kit. I highly recommend it to anyone who has doubts. You must have good skills. But it is so much fun. I am not a car warrior but you never know! LOL.
  37. #76
    Horseheads, NY
    That's awesome...I gocarted mine the same way (string). But 40 days? Very impressive and nice job!
  38. #77
    Feb 2013
    Xenia, OH
    40 days, by yourself, must be some kind of record. Nice job!
    FFR HR #530
  39. #78
    Outstanding
    FFCars - lowntubd
  40. #79
    La Verne, Ca
    I can't believe it... That's awesome. So jealous. Great job.
  41. #80
    Well I have not posted for a week now. I came down with a bad internal infection and fought a fever for 4 days. I am fine now and back at it. I worked on the trans tunnel and will mount it tomorrow. I finished up some wiring as well. I was able to mount the body using a winch and straps by myself. It worked very easy to my surprise. The firewall is off on the LS. Where did I hear that one before? So off the body came. Today I made holes. I cut out for the gas cap, dash insert I made, the access panels in the front, A/C and defrost vents. I was glad I did this outside. Fiberglass dust city. I broke my camera. I had to borrow the wife's. Don't tell her! I see everyone else is making progress as well. Keep up the good work!.
