Results 1 to 12 of 12
Thread: Door Threshold and Side Carpet Trim Options
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    All,
    Doing the final interior install (finally)…
    Looking for some options/suggestion to clean up the door threshold area and the outside corner areas next to the door.
    Any/all suggestions are appreciated.
    Mark
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
    I make it out of a single piece. only thing left will be a small triangle are that will need to be filled at the bottom of the "v" FFR sells the carpet by the foot.
    Dublin, OH
    RJD's Avatar
    Northern Virginia
    This stair edge worked pretty good.
    Dec 2017
    Southern Ontario
    I use the same as Chewy, you can get it in 3/4 or 1"
    https://www.homedepot.com/p/Alexandr...6C01/205576693
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
    Mar 2017
    Thanks all. This was the direction is was thinking about going. I will look into some trim options.
    Any other creative options/suggestions for the body to interior transition?
    RJD's Avatar
    Northern Virginia
    Quote Originally Posted by mlewis View Post
    I used some textured 1/8" ABS plastic to clean up the locking post area. Easy to cut to fit and then bend around the corner with a heat gun.
  8. Likes Al_C liked this post
    On a roll Al_C's Avatar
    Wheaton, IL
    I did the same thing, only mine is plastic. I like Chewy's better. The plastic breaks eventually.
  10. #9
    Dublin, OH
    I got black anodized aluminum from online metals dot com. Blends in with the carpet better
  11. #10
    Dublin, OH
    are you talking about the under door part of the body? most use that C channel trim piece to hide the transition. Dark water customs made a polished aluminum trim piece, but I think Chris is no longer making products. I actually had my hands on a pair of these transition pieces but sold them as it required some shaping to fit correctly and I didn't want to mess with it on a freshly painted car.
  12. #11
    Mar 2017
    Yes, that is the area and the kind of option I am looking for (I recalled see the dark water option but couldn’t find it)
    Any other options out there ??
  13. #12
    Dublin, OH
    unfortunately, I don't think so.
    just checked DWCs website and it's confirmed that he's shutting down operations and is no longer a vendor.
