Results 1 to 17 of 17
Thread: Radiator Panel
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Radiator Panel
    Hi all,
    I am contemplating using Mike Everson's radiator panel on my build http://www.replicaparts.com/Roadster...nel%20page.htm
    The suggested radiator angle is 58deg. (vs 51 deg. for the standard install). When I mocked up the placement I noticed the lower radiator outlet is very (too) close to the frame (tow hook).
    For those that used Mike's panel, I was looking for some suggestions on how to you addressed (special hose, altered the panel). I would prefer not to have to alter the frame.
    Thanks in advance.
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
    Tybee Island, GA
    My lower hose also interfered with the tow hook. I have the top of my radiator on a piano hinge, so I propped it up as high as it would go and took the skill saw to the tow hook tip. I still have the tow hook, but it has been trimmed to clear the lower radiator hose.
    trimmed tow hook by D. R., on Flickr
    20170826_121531 by D. R., on Flickr
    20170826_122950 by D. R., on Flickr
    Videos are at: YouTube Videos
    Raleigh NC, OIB NC
    I just eyeballed mine to fit but I also have the breeze lower radiator pipe system not the FFR ripple pipe.
    I also used the lower support package, don't remember who I bought it from & the Breeze upper panel (not in the picture) to seal the opening against the body
    Kevin
    MKIV #8234
    Mar 2017
    Thanks for the feedback.
    Kevin - do you know what angle you set your radiator at ?
    I'll have to look into the lower radiator hose option from Breeze.
    May 2018
    Quote Originally Posted by mlewis View Post
    Hi all,
    Thanks in advance.
    I just bought one for my MKIV 8687. I have the task of installing it on a completed car. Should be here in a week or so and I will post pics for you.
    Raleigh NC, OIB NC
    No I never measured it. Just clamped it all it & locked it down when it fit.
    Just saw the picture in the thread that AC Bill posted. Mine is the same its the Breeze Lower Hose. Good clearance & no pop-off issues like with the corrugated unit. On the COYOTE my upper hose in an F150 piece when equipped with the COYOTE engine.
    Kevin
    MKIV #8234
    It's an old issue that others have had to deal with. Here is a couple of suggestions for the fix..
    https://www.ffcars.com/forums/17-fac...l-not-fit.html
    Mar 2017
    Thanks gmagno, I look forward to seeing your solution.
    Thanks Kevin
    Thanks AC Bill. I will have a look
    Senior Member DavidW's Avatar
    Stevensville, MD
    I got Mike Everson's radiator panel and tried to install it but failed. My radiator is at 58 degrees with the Breeze lower support, I measured a bunch of times, even used some poster board paper to get the fit just right but I couldn't get the aluminum in there. I ended up getting it stuck at one point and bent some fins on the radiator then got frustrated and had to completely fold it up to get it out ruining it. I ended up making side and floor panels with 0.40 aluminum and found I like that better. Then I had to straighten the radiator fins out, what a pain..
    I'm guessing the Everson panel is ideal prior to the body mount as seen in the pictures posted but I just don't know. Good luck.
    Jun 2015
    Fairfax Station VA
    I used a Dremel with a grinding wheel to take about 1/4" - 1/2" off the tow hook. To get the maximum bend into the F5-provided hose, I put one end in a vise and then bent it over using both hands and no gentleness whatsoever. And to make sure the rubber adapters don't pop off, I put three 3/16" rivets in the metal hose.
    IMG_3481 by jhsitton, on Flickr
    IMG_3443 by jhsitton, on Flickr
    MK IV Roadster #8631
    mlewis (and DavidW),
    I went a different route, in that I used the existing FFR lower rad pieces, and then made a stainless steel insert shroud that I put in after the fact. Why stainless? Because it can be rolled up and unfurled inside the nose. These pics tell the story:
    Standard metal, powdercoated and installed along with lower breeze rad support for adjustability:
    I made lots of paper, and then corrugated metal template designs(and corresponding scrap), getting the shape right:
    The final shape. (MKIII is different than MKIV):
    This is the good part, the install. Just roll it up...:
    Place in the opening and with just a little coaxing it will "spring" into it's place. :
    Then I used one rivet on each side and 3 in the front to hold it in place:
    That SS insert is 'trick" David. What a great relatively easy winter project idea. Is the SS sheet corrugated from the supplier?
    Mar 2017
    Agree, David Hodgkins I like this solution for sure.
    What gauge SS did you use ?
    Did you follow the position (angle) of the radiator per the standard install (51 deg.) ?
    Hudson Valley, NY
    I used Everson's piece, installed after body was on, adjusted radiator to fit. My lower hose (kit supplied) sits on top of the tow hook, I ziptied it in place to the tow hook, no issues
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Anyone have any suggestions on how to contact Mike Everson. I've sent him 2 emails from his site requesting a quote for shipping on his radiator panel per instructions on his site, no response yet.
    JR
    Sorry Cruz. Very busy. I will respond today.
    Stafford Virginia
    Thanks Mike. I suspected you were pretty busy. I've answered your email.
    JRcuz
