0
0
Originally Posted by
broku518
I wish I knew about the velcro or installed the screws bit lower. I used rivnuts and screw/washer to support my dash. After I installed the fiberglass is covering half of the screw, looks kinda funny. Tried to remove the washer, but it leaves imprint in vinyl dash. Guess I will have to live it it.
Martin,
Sorry about that. I know you followed my lead on the rivnuts and screws. The good news is that those indentations in the dash from the washers will eventually fade away and return to the original smooth surface. When I installed the glove box latch and then changed it to the VW part, I had a similar impression left by the original latch. It slowly faded away.
