Skelly,
Welcome to the forum!
Here is some information regarding the registration process in NYS.
http://thefactoryfiveforum.com/showt...2168#post32168
Having done a Roadster, the process is not that hard but you will have to dot your I's and cross your T's. Remember you are dealing with two different State offices with their own agendas. The bumper issue will be easily solved by creating a simple removable set up for photos and the initial inspection. Then just pass them on to the next builder going through the process, much like the hot rod guys.
My BIGGEST words of advice, make sure you have CLEAR TITLE to you engine and transmission. You don't want to be the next guy to have to pull his engine at Tech Inspection because your number did not match.
LMK if you are close to Albany, I'd like to see your build!
Good Luck!
Pat
