josh7owens
Going to a RSX trans would eliminate the adapter plate and flywheel but would require a custom setup for the shift linkage, trans mount, and axles.
And a lot of frame and suspension re-work! Frank818 originally considered mounting his VR6 sideways in his 818 with the VW transaxle, but realized the entire rear suspension would need to be redesigned to accommodate a transverse drive-train layout. His VR6 fits, but he ended up with a longitudinal orientation, bolting it to a Porsche transaxle, IIRC.
wleehendrick
Exactly! So the question is, what is the physical size of the 2007 WRX STI motor and will a K24 block fit in the same space without having to move anything; I.E.-the trans back.
I wouldn't want a 800whp or 1000whp but mid 600 with an borg warner EFR turbo with a anti-lag setup similar to Robert Thornes S2000 CR and the car would be nasty with very little turbo lag.
I'm still confused on why no one has done this yet.
josh7owens
The EZ30 is the longest motor that fits longitudinally, from
http://phantomotaku.com/SVX/011822-MSA5P0631C.pdf
the length is 18.3 inches
Your dimension above is 20", so it won't fit without mods to the rear firewall.
The trans is about as far back as it will go.
The adaptor plate might also make this worse.
You'd also have to mod or relocate the tank,
and motor maintenance in a C would be tight.
Other than that, go for it. Frank818 has proved anything can be done with enough perseverance
