That is nice work. How will you keep the slip fits from leaking?
Thank you for the compliments, it's always nice when a plan really works and you get to learn something along the way.
I was extremely tentative to start this and wasn't sure I made the right decision. But all you need are relatively basic tools and a boat load of patience, so I'd highly recommend giving it a shot. My main tools have been a regular chop saw with a thin kerf abrasive wheel(3/32"), a die grinder with sanding drum to clean up the internal slag from cutting(a dremel would work just as good...), and a disc sander for the outside slag. Having a cold saw and other tools would be nice but I found not necessary at all. If you enjoy fabrication like I do, it's a very enlightening and educational project. I'll have less than $150 in supplies to complete BOTH headers, so it's a pretty good cost to effort ratio as well. Heck I blew more than that on a few other options that I'm now regretting....
Craig, there actually aren't any slip joints on the headers. If you're talking about near the sidepipe flange, that's where I had a muffler shop take my 1-7/8" tube and stretch it with a hydraulic stretcher to get out to the 2" diameter of the flange. The stretched tubes are then welded both internally and externally to the flange.
-TJ
