Here is a picture of mine that I took when I was figuring out how much I needed to cut off of the rod.
I also had the set screw wrong in this picture and was not using the small one they provided.
EFI Rules and Carbs Drool
TDSapp
I think the guys hit the nail on the head, it doesn't look like you have the correct joint at the firewall. Unless you have a Coyote or other engine than needs extra clearance, the third bearing is unnecessary.
