Results 1 to 6 of 6
Thread: Running boards
    May 2016
    North of sacramento Ca.
    Running boards
    OK, what have anyone done to the running boards to keep them looking good? Mine are going to be yellow and well use them.
    Simi Valley, CA
    I haven't fabbed the parts yet, but I plan to cut 3/4" wide strips 4' long from 1/4" thick HDPE sheet stock. The running boards will then be sandwiched between these strips and the 3/4" square steel tubes supporting the boards from below.
    If that doesn't work to keep the running boards looking good, plan B is to adapt stock solid rubber mats from one of the aftermarket antique Ford parts suppliers.
    Keith
    Senior Member JOP33's Avatar
    Haslet, Texas
    May want to try having a clear vinyl wrap installed in those areas.
    Onalaska, TX
    Keith
    Keith,
    Where did you get the kit for the running boards? I was going to make my own but, these look like store bought. info please.
    May 2016
    Yea been thinking about the rubber over. I would like yellow, but with paint or or clear i see no way to keep looking good.
    Simi Valley, CA
    Quote Originally Posted by Dodgeman View Post
    Keith,
    I bought the FFR fender + running board package with the kit (50/50 sale), but then wanted something a little different and bought front fenders and running boards from a non-supporting vendor. PM me if you need a referral.
    Quote Originally Posted by 1932 View Post
    IIRC, the HDPE sheets are available in a variety of colors including yellow, if you want to go that way. You will probably have to go to a marine supply place to find it though - McMaster Carr only carries it in black or gray.
    Keith
