Papa - have you verified that you can remove your dash with the body on? I thought the fasteners had to be moved below the hoop so they wouldn't be covered by the body...
Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, currently a roller.
Gen-2 Coyote, clutch, TKO600, midshift, and solid axle from Forte. Many pieces from Breeze and Replicarparts.
I hadn't intended to make the dash removable with the body on the car, and after test fitting the body, the screws are mostly covered by the body. A removable dash is something a lot of guys have done, but it is more than just getting the dash loose. To do it right, you need to plan for a few modifications in the wiring to make it easy to unplug everything.
Delivered: 6/17/2017
First Start: 12/30/2017
Completed: 12/7/2019
Legal: 1/30/2020
