Results 1 to 22 of 22
Thread: BP 427 Dyno Results
    cv2065's Avatar
    BP 427 Dyno Results
    Looks like my engine will be here on Friday from BP. I asked Johnny for a dyno sheet and torque numbers look really good with 455 lb-ft at 2500 rpm, maxing out at just over 500. I thought I'd share in case anyone is thinking about this particular engine.
    Great numbers! That should be a beast.
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    Great numbers! I love my BP 427! You getting fuel injection or carb?
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
    cv2065's Avatar
    Quote Originally Posted by ILPBFoot View Post
    Thanks Dave and Steve. I'll be going carb! If all goes as planned, I'll be putting engine and trans together this weekend.
    BadAsp427's Avatar
    Greeneville, TN
    Show off!!!! Heck yeah you better show off!
    cv2065's Avatar
    LOL...Now just need to get this thing built and running! Thanks again for the help by the way!
    Sweeeeeeet!
    I'm about 50 ponies behind you so Beeeeeee Careful.
    May 2016
    nice numbers and gobs of power, get ready to brake the tires loose at will. I am getting used to my car at the moment and its just wheel spin city even with the wide 315 rear tires.
    cv2065's Avatar
    I was reading your post earlier about tire spin. I’m sure it will take a little practice and discipline to keep everything civil.
    I bought the same motor but went with Holley EFI Sniper system. Made maybe 10hp less than your's did, but I doubt I'll miss them at all!
    Northern VA
    Great numbers. I bet the cam isnt too radical either. Very driveable and more than enough power.
    cv2065's Avatar
    Quote Originally Posted by scottiec View Post
    Cam is interesting...
    Cam Specs:
    Roller cam
    .608 intake .608 exhaust
    248 intake / 258 exhaust @ .050
    114 degree lobe seperation
    Consider getting a Rev-Limiter and set it low and work your way up.
    I added one when I replaced my block and in my case the unit is easily adjustable.
    https://www.jegs.com/i/MSD-Ignition/121/8727CT/10002/-1
    The car starts spinning the wheels by rolling on the throttle at or around 2600-2800 RPM's, but hits the limiter at 4000.
    This is how I'm learning to stay out of the ditches as I work through my Go-Karting testing phase.
    Your Car Will Be A Total Beast!
    BadAsp427's Avatar
    Greeneville, TN
    The MSD Distributor that comes with the BluePrint Engine has a built in Rev Limiter, very easy to set and Oh, Yeah, I'll be setting mine...
    May 2016
    mine is set to 6200 rpm on the fitech. My right foot is my rev limiter. If she starts to slide out from under me I let up a bit very quickly. Run dual (skinny spring inside larger spring) return springs, make the skinny pedal stiffer. You will be glad you did.
    Got some stuff done tonight and sat in the car and rowed some gears. All fluids are in the car. I am using 30 weight zinc Amsoil for break-in (second oil change with different oil and filter). AMsoil Synthetic AT trans fluid in the t5z and amsoil in the rear gear. The coolant is Prestone Concentrate (17 a gallon).
    Got the gauges in the car using the provided dash from ffr. I hate it and I am going to change it.
    Also completed my gas pedal install. I used clean looking fox rubber pads and the FFR pedal. I really like this pedal. The FFR cable kept coming undone so I went to pep boys and bought the LOKAR 36 inch cable and throttle linkage bracket. 100 bucks and done. I must of spent most of the day messing with the crappy FFR throttle cable. Throw it out! I used 4 washers and a bolt to make my cable stop. I also checked it against my FITECH computer. at the stop I am at 100.5% WOT. Very happy with the feel. Its very stiff with the extra springs and will allow me to not blip the throttle unless I hammer it. Much more control.
    Jax Beach, FL
    Looks good!
    As other have said, rev limiter. Also, please put tires on your car that are up to that level of performance. 200 treadwear is what I run with a 500hp 347.
    Always be prepared for it to break loose as the RPMs climb. Mine comes on like a freight train at 4000rpm.
    If it starts to break loose, roll out of the throttle and the car will grip. DO NOT completely lift. You can get a lesson in trailing throttle oversteer on a panic lift.
    I recommend doing at least a couple autocross events to learn what you and the car can do.
    cv2065's Avatar
    Looks good!
    Thanks Avalanche...As Carl said, the BP engines come with the rev limiter, so should be good to go there. I've got the Nitto NT555 G2's, which have a 300 treadwear. I'm assuming that should be sufficient.
    I think I'll treat the car breaking loose like I do when driving in heavy rain. As you start to hydroplane, roll off the throttle and the tires will grip. Would love to do some autocross events when the time comes. I'll have to look into what's available around here. Maybe there are a couple that would like to join me!
    May 2016
    I have NT555 G2's with 50 miles on them right now. The rubber is still very hard and I am not impressed with the grip. 275 front 315 rear. I wish i had gone with nt01's
    I feel your pain, but in a bit smaller tire combo with 245/40-17's up front & 285'/40-17's out back.
    I went through three (3) sets of the 555's on my former daily driver and they were great, so great that I put them on my MK-4.
    https://youtu.be/svZX2BMSDEs
    The problem is that my former beloved C-4 had a 1/11 Horse Power to Weight Ratio and my Roadster is very likely at 1/5, maybe 1/6 at the very least.
    They don't stick with a: Slang Word For Excrement!
    cv2065's Avatar
    Man that sucks guys! I've got 255 in the front and 315 in the rear. Guess we'll see!
    cv2065's Avatar
    Just saw this about the Nitto 555 G2's:
    NOTE: This is a high-performance tire intended for use during summer months or warm temperatures only. Use during cold weather will greatly reduce performance, traction and handling, and greatly increase stopping distance. If using this tire in a drag or track environment during cold weather, we strongly recommend performing a pre-run burnout to nominalize the tread compound's temperature.
    Guess I'm glad I live in Florida....
    May 2016
    I'm in texas and it has been in the 70s.
