Results 1 to 12 of 12
Thread: Phenomenal Products & Phenomenal Service
    Earlier this week, Wednesday morning before we headed out for Cruising The Coast, I called Mark Reynolds at Breeze Automotive and ordered 4 side pipe wedge plates.
    This evening they showed up in my mailbox so you all know that I had to start swinging wrenches, even though I'm tired as hell after a week of cruising.
    Anyway, the wedges worked perfectly and my side pipes are now mounted and spot-on perfect because I have his wedges.
    The moral of the story, If You Need Something & Mark Has It, Then It Will Work & Work Well!
    The other piece to the puzzle is that it will get to you as quickly as promised.
    If you need to tweak your pipes, then get these wedges:
    https://www.breezeautomotive.com/pro...egory/exhaust/
    Thanks Mark!
    PS: I have his seat mounts and fan shroud.
    I have a lot of Breeze parts and every single one has worked as advertised and showed up quickly. The only one that shipped slow was a drop-ship. I have found myself reviewing his (new) website just to see if there's anything else I need...
    Senior Member jrcuz's Avatar
    Stafford Virginia
    I've gotten several items from Mark and always satisfied plus he always has a few minutes to talk.
    JR
    Chino Valley, Arizona
    Couldn't agree with you more, Mark is a good man with great products and customer service.
    Copperhill, TN
    Mark’s service and products are both outstanding. That new led light package looks impressive.
    mburger's Avatar
    Punta Gorda FL
    Got my power steering setup from Breeze as well as other items. Great guy to do business with. Going to get his fan shroud and radiator mount kit. Can’t say enough good things about Mark.
    Mark
    Jacob's Avatar
    Rogers, AR
    Never been disappointed!
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Making it up as I go. JJ in Cbus's Avatar
    Columbus, Ohio
    Great parts, great service, and Mark answers his own phone. ...and sometimes at the most damnedest hours!
    We're All Here, 'Cause We're Not All There.
    Member ChasNMe's Avatar
    Sep 2018
    Charleston, SC
    why would you need 4 plates, seems like one on each side would do the trick? im new here so I don't know squat. . . . reading a build manual and writing down questions . . . im up to about 50 questions and 60 pages in. thanks for the info, jake
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by ChasNMe View Post
    Chad, each plate give you an adjustment of one angle. (unless they are flat plates) with two you could angle in/out and up/down if needed. Just allows for some extra fine tuning. and also, it could give you more outward placement to get the pipes further away from your paint.
    A Big Bingo On The Fine Tuning Da-Pipes!
    Since we modified some IMCA Headers and then had them welded we had some pulling that was not anticipated so I needed wedges to get them to be spot on perfect.
    One side needed to be angled up while the other down to make them work out, plus we used the smallest wedges to really fine tune them.
    In addition, to address the left pipe droop (Not Parallel To The Body) I used 3 - 5/16" bolts and 1 -3/8" bolt which corrected this issue.
    If you look close at the attached video you will see that my left pipe was angled a bit down when we shot this early test drive footage.
    https://youtu.be/NhRHwAbtrt0
    Schoenfeld IMCA Header #161-33 Were The Headers I Used As My Starting Point.
    https://www.schoenfeldheaders.com/im...modified5.html
