Looking at my Ron Francis fuse block as received, it looks like the fan control wire is not jumpered to the fan relay or any relay for that matter. Looks like they did not install a jumper at the factory. I am running a Gen 3 Coyote so I think I can bypass the relay anyway and connect the orange fan wire from the Coyote harness directly to the blue fan wire. Or is there an advantage to using the relay on the Ron Francis fuse block? Seems redundant as there is a relay in the Coyote module.20200531_180750.jpg
