Not a waxer
Unfortunately with the stack of wedges that it took to get the pipe to run parallel with the body it's going to be hard to keep that joint secure...just a little at each face will add up to a significant change at the end of the sidepipe. Best I can come up with is to raise the rear hanger to keep some tension on it.
