25th Anniversary #9772
Jeff Kleiner
Video,
A Mustang booster is in no way compatible with the Wilwood dual master setup.
yes the Whitby setup can be used with the Wilwood Pedalbox - you get a new brake pedal arm with a mounted post
there is a decent amount of drilling involved for the vacuum booster to fit properly, at least 4 holes need drilled
https://cobradreams.com/2020/05/18/c...-power-brakes/
Not a waxer
toadster
But as I said (over 2 tears ago, in the quote that you included) the Mustang booster is not compatible with the Wilwood dual master cylinders. If you use a Mustang booster, either with a Mustang pedal box or Wilwoods you end up with a single master cylinder and lose the ability to adjust front to rear bias hydraulically.
Reading comprehension. Don't teach that in school anymore.
Jeff Kleiner
ah yes, I see now - yes you do not need to use the dual masters with the mustang booster it converts to a single - I thought the comment was about it not working at all - my bad
and yes rich grsc I'm not worthy LOL
