29
38
25th Anniversary #9772
edwardb
I've done three builds that required a MAF intake tube. This one uses these parts:
Spectre SPE-9705 Mass Air Sensor filter adapter, Spectre SPE-9741 4” to 3.50” Reducer adapter, Spectre SPE-9771 4” hose coupling, Spectre 4” 90 ° intake tube, Spectre SPE-9799, Spectre Performance 8130 Small Air Filter Heat Shield
My Coupe (Gen 3 Coyote) uses these parts:
Treadstone Performance MAPHL35 MAF Mass Air Flow Adapter Pipe 3.5", Treadstone Performance ACCH35 HoneyComb MAF Mass Air Meter Airflow Straightener - 3.5", Treadstone Performance S35090BLK 90 Degree Silicone Hose Couplers 3.50" - 3.50"
My Truck build, although an LS3, uses similar parts and the Performance MRP MAF adapter pipes have been used in Coyote builds:
Performance MRP HA-SS-400D6 Mass Air Flow Housing with Air Straightener, 4.00" OD, 3.75" ID, Summit Racing SUM-294068 90 Degree Elbow, Silicone, Black, 4.00 in. Inlet, 4.00 in. Outlet, 6.00 in. Legs
So it's been kind of a mixed bag and you have various options. Spectre parts weren't available during certain periods, so the Treadstone Performance parts were referenced as an alternate in the Factory Five instructions. Those also started to be more difficult to obtain, so Performance MRP because an alternate. The Performance MRP part I purchased for my truck build was in stock and shipped immediately.
always a treasure trove of info Paul!
did you use the 2 flow calibration tubes - (76 millimeter and 89 millimeter) which reduces the 4 inch intake system to the correct diameter at the sensor to retain calibration. from here: https://www.spectreperformance.com/9...or-adapter-kit
toadster
For the Spectre intake I used the reducer as described in the FF Gen 2 Coyote installation instructions. I can't tell you exactly which one it was because it was some years ago. But just to set your expectations, nothing you're going to do with the MAF tube is going to retain calibration. Without the OE stock airbox, the MAF calibration will not be correct. The custom tune required for best running Coyote installations addresses this. The Gen 3 Coyote in my Coupe was undriveable with the stock tune and was fixed by the Lund Performance custom tune. The guy that did the work said a high percentage of the tune adjustment (and the cause of my undriveable condition) was the MAF calibration.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
edwardb
awesome thanks - there is no mention of the Spectre intake in the gen3 documentation, just the silicon hose that FFR provides, good to know there's historical content to review too!
I'll reach out to Lund to get their recommendations too -thanks!
