Your steering arms (that bolt onto the spindles) appear to be backwards.
They should be pointing slightly outward instead of slightly inward.
Rob Windsor
Terry
I installed the hubs this weekend, but ran into a snag (pun intended) with the FFR-supplied Mevotech units. As others have noted, these often don't just slide on like they should (do not force them!). During my initial fitting, I hit resistance at about an 1/8" of engagement on the spindle. I gently removed the hub and part of it decided to stay. I ended up with this:
I never really liked the quality of the Mevotechs based on what I saw and felt, but I know they've worked well for many. Despite that, I pulled the emory cloth from my plumbing tool box and polished the spindle. The second hub went on further, but again I gently pulled it when I hit the least amount of resistance. Same result as above. Ugh. Now I know these are largely held together by the preload of the axle nut and maybe I could have just popped them back together, but this did not give me confidence. Screw it, gonna buy new ones. The local NAPA store was having their monthly 30%-off sale, so I picked up a set of their premium hubs manufactured by SKF (good!). Still made in China, but what isn't these days.
These units are clearly much higher quality... tighter, no grease oozing out the seals, etc. I'm not sure if the studs are black for cosmetic reasons or if they're a higher grade steel. Doesn't really matter, as I was happy with the purchase. I will say though, regardless of the hubs you use, be sure to clearance the spindles with emory cloth or equivalent. It doesn't take much, but it makes a huge difference.
I realized I didn't removed the ABS tone rings until after I torqued the axle nut (of course), so a few quick passes of the dremel and they popped right off.
Terry
I got the P/S rack installed. The [URL="https://breezeautomotive.com/shop/offset-rack-mounting-kit-for-ffr-roadster-and-coupe/"]Breeze mounting kit/URL] is awesome and makes centering the rack a simple process. There's not much to installing the rack other than figuring out how to fit it in. I also used Moog tie-rod ends.
Terry
