0
0
I think it depends if you are building an S, C, or R plus if you will be using the FormaCars wiper kit. This forum page gave a lot of detailed info on different mounting locations. I am building an R so it might be a little different but I am going to use the FormaCars wiper kit so I mounted mine in a very similar location as post #13 in the following link. I went with a Tilton remote reservoir so a little different as well, but the link has some dimensions which you may be able to use FWIW.
https://thefactoryfiveforum.com/show...ighlight=wiper
