And a nice go-kart session today in the Florida sun:
https://youtu.be/K2mC-VPa-Gc
Sorry the audio sucks. I've gotta figure out a better microphone. This one is remote but cheap.
Matt
My build thread here
Depending on your physical build, you might want to sit in the seat and see how the dash button locations work out ergonomically. Things to the left and under the steering wheel are not the most accessible for me.
Good job on the trans.
Thank you. Since you mention it, I've chosen that location for the turn signal buttons because I'm used to using my left arm for turn signal action, and in manual cars I tend to keep my right hand on the shifter. BUT, do you think there's a chance the top of the door will be in the way for my left arm to comfortably access those switches?
Clearly I don't have the door installed so I wouldn't know the difference. Why was it an issue for you?
Matt
I thought I would mount something on the left side of the steering wheel, forgot what it was.
I must have had the body and doors on, when I found out the reduction of area and access.
I ended up putting the horn button on the dash, to the right of the steering wheel.
My headlight dimmer is on the Russ Thompson turn signal lever.
I must not have a pic of the my dash. I do have a panel on the trans tunnel to dash support. I have a power outlet, 4 way flasher and wiper switch on it.
Too cold to go to barn for pic taking, today.
Maybe others will chime in.
good luck,
I've built several cars using a self cancelling Signal Dynamics module (which uses momentary switches for activation) rather than a Russ Thompson style column mount and on all of those located the controls to the left of the wheel. It works and as you say seems more natural.
On my own car I used a 2 position momentary rocker switch (actually a power window switch). The toggle is high/low beam and the momentary push button is "flash to pass:
The customer for this car preferred a long stem momentary toggle; up=right, down=left. Again the other toggle is high/low beam:
The customer for this one preferred two momentary push buttons to the left of the wheel but asked me to put the low/high beam toggle on the right.
Hope that helps!
I like the idea of putting them to the left of the tach, I just figured the curved nature of the dash wouldn't allow for a 19mm diameter momentary switch. I'll take a closer look. I also like the idea of putting a hi-lo toggle over there as well.
Matt
Matt
I set them up with keyed and fused 12 volts, just like conventional turn signals. That can come from the turn signal feed or wherever else you care to grab it. I prefer keyed power rather than constant hot so that people can’t activate them while the car is parked.
I'm too excited to not share this, but I just spent $700 at Spintech for all my low-profile exhaust components. I'll be sure to post pics of the fabrication and assembly, and definitely sound clips.
Matt
I installed a smaller clutch MC today. The last few times I went out I grew annoyed how touchy the clutch was. Wilwood sells a bunch of different sizes, so I did some quick math and went with a 15/16" MC. The clutch onset is so much smoother now, less grabby, and easier to leave the line and go backwards up my driveway.
Matt
Gonna have a fun couple a weekends:
Matt
Wow that is definitely a different mod for the MK4. I will be interested in your install and see how it looks.
Roadster MK4 #10653 Date: 4-27-23; First Start: Oct 2023; Go Kart: Nov 2023; Body and Paint: To Kleiner EDD - April 2024; Graduated: TBD
SBF Boss 347, Edelbrock ProFlo 4, Milodon Road Race Oil Pan, Tremec TKX 2.87/0.81 OD, IRS Dakota Digital Dash, FFMetal Firewall Forward, BOIG Lower Cool Pipes, Forte's Mechanical Throttle Linkage and Hydraulic Clutch, Breeze Radiator Fan Shroud- Radiator Support Kit and Battery Forward
The design intent is to run the oval tubing and muffler right under the seats, then ditch out in front of the rear tires. I'm gonna put a 1/4" strip of wood on top of the mufflers and jack them up firmly before welding the hangers so they're actually hanging a bit, but up as high as possible. Then a buttload of insulation under the seat.
There's a fella on here who's done the same thing. The end game here is the "Gentleman's Cobra". Metallic BRG paint with an under exhaust, but since I'm solid axle doing tail pipes would be difficult.
Matt
This may be of interest:
https://www.ffcars.com/forums/17-fac...t-halfway.html
I'm the current owner of the car shown in the thread above--exhaust was fabbed by the prior owner/builder.
MK IV #8639, 347/T5
Matt
Drivers side. Went together pretty easily. Some custom cuts to adjust angle, but for the most part not bad. It's just tacked together with the Flux Core, but I'll TIG it for the finish welds. And I'll whip up a hanger on the back end. I got started on the passenger side but dinner was calling before I got to the J pipe.
It'll all get a coat of high temp paint, and header wrap from the O2 sensors down to the muffler to try keeping heat inside the pipe.
Matt
I find this interesting. On the original 260 & 289 Cobras the exhaust ran under the car and out the back. The 427SC had the sidepipes we all know. What you're doing is under the car but exiting at about the same place as the sidepipes. Is it just to eliminate the big sidepipe and clean up the lines of the car? I'm guessing with those mufflers it will be quieter than with the sidepipes.
I hope you're able to insulate well enough to keep from roasting your butt. When I was looking to buy a Viper I looked at a few Gen III that had the exhaust under the car and out the back. The heat from the exhaust in the cockpit was noticeable. I ended up buying a Gen IV where they went back to the sidepipes and no heat in the interior.
Looking good so far!
That's interesting Mike, I always thought the 427 had the full under exhaust and the 289 had the side pipes.
Regardless, my end game is the Gentlemen's Cobra. British Racing Green and no pipe to sting your lady's leg.
I'll definitely post a sound video when they're done
Matt
Spintech exhaust fabricated, but not yet painted and insulated:
https://youtu.be/59DJ5jZvCo0
I'll be painting, then wrapping the pipe up to the muffler, then partially wrapping the top and inside of each muffler with some aluminum backed fiberglass to keep heat off my bum and the fuel/brake lines.
Matt
From the "Took long enough..." department, exhaust is done and installed:
Header wrap down to the muffler, then fiberglass backed aluminum around the top and inside of each muffler. Hopefully that'll keep the heat at bay (somewhat).
Matt
After a few more miles go-karting around the hood I decided I wasn't much of a fan of the pedal positioning, so I made some modifications. Firstly, the brake needs to be further out, but there's a frame member in the way:
I didnt' want to push the seat forward because I like the positioning the way it is, so I made some adapters.
I finally got to use those Harbor Freight letter stamps too. Now it's perfect!
Next up, raise the gas pedal a scootch, and scoot the clutch over as far as possible, just to make the pedal flush with the Wilwood arm.
Matt
I've had heartburn over that panel bend on the throttle side of the footbox because my toe kept hitting it, so I picked up some sheet aluminum and a metal brake from Harbor Freight and went to town. First with some cardboard, then the final product. Two pieces later:
I also scooted the clutch pedal over one hole space and used a metal plate to distribute the load. It looks a bit goofy but works great. Now I can wear normal shoes and not worry about my foot hitting anything unintended (like the gas when I'm hitting the brakes...)
Matt
I know I had to shorten the driveshaft to work better with the SN-95 bellhousing and input shaft I used from the donor, but I've had heartburn about it since I did it. Yes, technically it worked, but I wanted it to be just a smidge longer, and not welded in the center. So, I took the universal joints out of the driveshaft, took some measurements to see what size yokes I'd need, and ordered some. I already had some 3" tubing lying around, so I got the correct yokes for a 3/32" tubing wall and got to cuttin'.
The process was pretty straightforward, until I got to the point where you have to have the yokes indexed correctly. This was my way of making sure they are perfectly in phase"
Then I used my 20T press to drive the loose yoke home.
I then checked roundness, which was less than .005"
The garage was plenty hot so I called it quits before firing up the TIG to finish the job. When it's all done I'll bring it in for balancing.
I also worked on the dash a bit. From go-karting, I know I'll want my left hand on the wheel all the time so my right hand could be busy with switches and shifting. I moved the turn signals over to the right, bought a larger horn button, and also bought the 16A "brights" button to toggle those on.
Matt
FYI, they're size 1330 universal joints.
Matt
