5
mike, i've already spent the gas money i had for a ride in your car on beer! (just kidding!) your finishing touches are looking great. as for the venting of the crankcase, i use an fittings in the top of the valve covers, (bungs welded in to the top of each valve cover) connect them with hoses and a "t" an fitting and then run the hose to a remote aluminum tank with a filter on top. on front engine cars with filters in the valve covers i'd always get blowby into the interior when you were hard on the gas and the blow by would even get to the filter even with the plate on the inside of the valve cover blocking the hole.the remote tank install looks really clean and you can put the little tank where you want. (out of sight in the back of the gtm's bodywork) still dreaming about that ride....
