Thread: Wiper motor issue
    Wiper motor issue
    I have a new FFR Wiper kit.
    The motor works however when i install the wipers they will not turn the wiper arms!?
    if you hold the exterior wiper nob when it is turned on you can feel trying to turn but is "slipping" on the inside of the mechanism.
    Anybody else experience this?
    It is as if it is stripped on the inside somewhere?
    Did you grease the cable gear? Do the gears work without the blades? Try placing a paper towel between the blades and the glass to reduce friction.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    the gears work without the blades. but when you install the blades with paper towel under them the gears slip inside the motor.
    Jun 2015
    Ancaster, Ontario
    I just installed my wipers. I used 5/16 “ brake line for the tubes as they were easier to flare. Take each housing cover off and see if the cable engages the drive wheels sufficiently. The manual says you can slightly bend the housing to ensure proper alignment and engagement. There is also a tab you can bend to align the drive wheel. Did you bend the tubes smoothly enough and ensure the cable slides through each tube freely? I had to reorient my motor to provide a smoother initial angle to the first wiper. Hope this helps.
    MKIV #8740, Canadian base kit, Picked up Dec. 2015, ‘98 Cobra 4.6 l DOHC, T45 transmission, old style IRS, Art Cuesta dieted harness/Ron Francis chassis harness, go-cart July 2018.
    If gears are slipping inside the motor, I'd contact FFR. If the cable is slipping in the gear boxes at the wipers, it could be several possible issues.
    1. Gear box not properly installed
    2. No lubrication
    3. Ridgid tubing not installed properly
    - flares not seated in the gear box
    - tubing bends too tight
    - loose end tubing too short
    Legal: 1/30/2020
  6. Likes GoDadGo liked this post
    Jun 2015
    Fairfax Station VA
    The "not enough engagement at the wheel box" problem Joecobr describes used to be pretty common. As Joe says, there is some bending on the wheel box that will help the coil engage the gears. The other solution folks have found is to buy the ********** wheel boxes. However, I believe F5 changed wheel box vendors so that kits delivered after 2016 or so have identical wheel boxes to what is available at **********.
    MK IV Roadster #8631
    Lilburn, GA
    I originally had wiper issues. They moved on one direction, but not back down. I cut a couple 1" pieces of brake line (used brake line, the supplied tubing was so hard you couldn't flare the ends) and inserted into both sides of the wheel box and tightened the screws. The gear inside was NOT in the center. I ended up reforming the ends where they clamp on the tubes, centering the gear.
    thanks fellas. im going to pull the system and bench test/build it.
    Pain in the ***....
  10. #9
    Raleigh NC, OIB NC
    Not going to help tcsracing1 but just a thought. I would find out if your state requires wipers to pass inspection. NC does not for these cars so I never bought them. Some states will be OK with the clamp on ones to get through inspection with.
    As for occasionally getting caught in rain RainX inside & out works pretty well. Yes inside as it will also get wet. Cockpit stays dry in most light to medium rain if you can keep moving. Sucks when you have to stop for a light.
    Kevin
    MKIV #8234
