Likes Likes:  2
Thread: HELP!! Speedhut inverter/dimmer
    Dec 2017
    Southern Ontario
    Has anyone had one of these go bad? I am wiring up my dash with the RF harness and can get the pointers to work with the red/blk/white ribbon but can't get the backlights of the gauges to come on with the white/blk wires no matter what I do. Wiring is not my forte so if there is a way to test it I'll be happy to try that. I have tried direct blk/white to a 12V jumper. I did buy the gauges used but was assured they worked. Any help would be great!!
    Higgy
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
    Yes, the inverter has been known to be defective and/or fail. The version of the gauges that uses the inverter (there's apparently a newer version that doesn't...) won't light the AC powered backlighting without it. So direct wiring with 12V DC won't do anything. Ideas? Make sure the knob on the included little potentiometer is turned up. Make sure the knob on your headlight switch is twisted all the way clockwise. The dash gauge lighting circuit goes through the dimmer function on the headlight switch. Sometimes guys have that knob turned down to where the gauge lighting doesn't have enough voltage to light. The inverter needs the proper DC voltage in. Start there for the obvious possibilities. Next steps would be to start probing with a VOM. If you have to call Speedhut, I've found their customer service is very good.
    Dec 2017
    Southern Ontario
    Paul, does my headlight switch need to be in the mix. I put the 12V right to the blk/wht wires on the inverter, and played with the dimmer switch
    Jax Beach, FL
    I had one go bad. The replacement was a newer version.
    Quote Originally Posted by HiggyMK4#9579 View Post
    My response was assuming you had the dash wired. My bad. No. The headlight switch doesn't add anything if you're applying power directly. You can bench test the gauges. I assume you have all the gauges wired together with the supplied daisy chain cables. The black and white wires for the inverter should power the backlighting. Turning the pre-wired potentiometer should adjust the level. The 3-wire cable does the rest. Red = gauge power, white = pointer lighting, black = ground.
  6. Likes Higgybulin liked this post
    Jax Beach, FL
    12 VDC in 100 VAC out
  8. Likes Higgybulin liked this post
  9. #7
    Nov 2016
    "The i.e." SoCal
    Just a tip here. First car we used the Speedhut gauges in we tried the gauge lights in the well lit shop and could not tell if they were working. Turned down/off all of the shop lights and what do you know, they worked.
  10. #8
    Dec 2017
    Southern Ontario
    I definitely had the shop lights off, I think it's toast. Good news, as many have said before Speedhut has pretty good customer service! A new one is on the way.
