Thanks Thanks:  3
Results 1 to 8 of 8
Thread: Seat Install
    Village Mills, Texas
    Seat Install
    What have you guys used to mount the seats? I would like some ideas. I have looked at the mounts from Breeze but surely that is not the only option.
    Placitas, NM
    Andy, I bought these sliders and then used some metal brackets to raise the sliders 3" off the floor for better forward visibility. At the time I did this I couldn't find any uni strut which would have made raising the slider brackets easier.
    https://www.4wd.com/p/mastercraft-sa.../R-GNNN-620030
  3. Thanks HVACMAN thanked for this post
    Thanks for the tip Jim. They are on the way.
    Are you using the hardtop? If so, how is the head clearance with the 3" lift.
    Placitas, NM
    Yes, I'm using the hardtop. I'm 5'8" so your headroom may be more/less depending. I had 3 to 4" above my head to the top. At the moment I have the body off the car so I can't recheck it.
    I'm considering raising the drivers seat a little more, just need to have enough clearance for a helmet.
  7. Thanks HVACMAN thanked for this post
  8. #6
    I'm 5'8" also. I used to be 5'10" before gravity and a quadruple cervical fusion. lol When I get the body on I should be able to tell more. I just need to remind myself to check it with the top on since I plan to permanently attach the hardtop.
  9. #7
    Gatineau, Quebec, canada
    I'm 5'11" and with just the seat and no sliders its just about right. However, if I raise it a bit I will then need to lean forward to see the traffic lights so i am not sure that i will raise them until I have some real road under me. Right now I have lots of room above at least 3".
  10. Thanks HVACMAN thanked for this post
  11. #8
    May 2016
    North of sacramento Ca.
    I am 5-9, seat on floor with permanent top and liked it but because of back did some work on seat which raised about 1 1/2 inch. I liked it better lower.
