Results 1 to 3 of 3
Thread: Help with blue electric steering wirw and TKO600 speedometer connection
    Jun 2019
    Whitehouse TX
    Hello All,
    Where does the blue wire go from the electric power steering wiring harness?
    Also, in the kit came the speedometer module for the TKO, do we use it or the one in the transmission that plugs in place to the harness?
    The engine cranks over now; however, the fuel pump is not getting signal to turn on. It works if you jumper the wire you cut to make the Computer run the fuel pump.
    Thank you,
    Zach
    Nov 2018
    Scurry Texas
    Quote Originally Posted by sperger72 View Post
    Hello All,
    Thank you,
    Zach
    I had the same question. FFR says it is not used for the truck. I just tied it back inside the loom.
    Jun 2019
    Whitehouse TX
    Thank you. What about the speedometer module for TKO?
