Installing Enamel Cobra Emblems for Hood and Trunk
I picked up a set of the classic Cobra emblems for the hood & trunk. They have small pins on them, but I'm thinking it might be best to get rid of the pins and use 3M trim adhesive to install them. Any thoughts on this from those that have installed them?
For sure cut off the pins. I've always mounted mine with 3M 03609 Scotch-Mount 1/2" x 5' Molding Tape. Widely available and works great. Also available in other widths and lengths.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
wallace18
That is what I would do.
edwardb
Thanks guys!
Seems to be the general consensus over the years Dave... cut and stick....
Kurt
Build thread
Hi Papa / Factory Five community - i'm actually looking for a set of emblems myself - any recommendations where i can get some / sizes i should use-location / etc.?
Dremel the pins off and use the double-sided 3M tape.
Kyle
I cut the pins and use a drop of silicone so they sit flat...da Bat
j.miller
Me too, cut the pins off and used silicone, perfect!
Subscribed to see where people buy them from and preferred mounting method.
I'd tell you where I got mine, but don't want to risk the wrath of Dave H. for promoting a non-supporting vendor's products.
PM me and I'll let you know where to look.
#8 2" long woodscrew, right in the middle
rich grsc
If you use two screws, the emblem won't spin, unless you prefer the spinning effect.
Papa
I like the helicopter effect, plus it makes a sound like a spaceship.
rich grsc
Got to be real careful to get that screw right in the center or it will vibrate like hell.
George
OK.....A dab of silicone, two screws and packaging tape and we are good to go !
Build thread
I like a Gr8 3/8 bolt with a steel locknut, so the thugs cant necklace it.
Boydster
And there you have it.....There's always "ONE" guy who has to take just a bit to far. Just glad it wasn't me this time !!!...da Bat
3m moulding adheadive here but I used several layers because the car is curved and the emblems are flat. Worked great and very solid just expensive.
rsw81
Ordered mine from Finish Line
