4
Polycarbonate replacement windshield: I am surprised no-one has mentioned: www.opticarmorwindows.com Optic Armour does nothing but polycarbonate windshields. Just ordered a 3/16"x24"x72" sheet ($270) to replace my cracked windshield that appeared while fitting the Premium Top (even though I was so careful with all the screws). The wood windshield crossbar put pressure I think on the sun visor brackets. This then exerted pressure on the windshield edge by one of the mounting screws. I think the whole frame perimeter clearances for screws needs revisiting in the frame design. If the frame perimeter was just an 1/8" wider it would probably eliminate all the issues.
Originally Posted by
RobCYoung
Will you be able to bend the polycarbonate enough?
davekp
???? that's what everyone is using, Lexan is polycarbonate
