Thread: Help With Sheetmetal
    Senior Member TomH33's Avatar
    Nov 2016
    Parker,CO
    Hi
    I am getting ready for my body install and have questions concerning the weather stripping and location(so the sheet metal seals to the body) of the striker covers and fuel tank side cover. This is pages 425-427 in my manual. Is anyone at the stage where you could post a picture or two the manual is so vague.
    Does the striker cover go over or under the side sheetmetal and carpet. The position it shows in the manual would be under the side sheet metal. Which weather stripping do I use to seal to the body.
    Any help would be appreciated.
    Thanks TomH33
    Nov 2016
    Parker,CO
    Here is another item I am Not sure where it goes. Labeled 33481 & 33482 as cockpit rear lower corner L&R. CockpitRearLowerCorner.jpg
    Thanks TomH33
    Senior Member TDSapp's Avatar
    Frisco, TX
    Quote Originally Posted by TomH33 View Post
    Thanks TomH33
    Tom if you look at page 312 of the PDF manual (Version 2o) you will see where these go. In the picture of the manual they have red edges on them and they are at the very back pf the cockpit and on the side.
    Tim
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Jun 2018
    North Vancouver, BC, Canada
    Quote Originally Posted by TDSapp View Post
    Tim
    As I near a similar point in my build I'm interested in these questions as well. Tim, pg 312 of my PDF manual (2V) is the emergency brake section. What section are you referring to and we can try to find it in the table of contents... Steve
    Gen 1 '33 Hot Rod #1104
    Frisco, TX
    It's the picture right above the EBrake handle assembly page.
    Let me save you some time though...
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  6. Thanks FF33rod thanked for this post
    Likes wrp liked this post
    Jun 2018
    Ahhh gotcha, 309 in my version...
    Nov 2016
    Parker,CO
    I got where the rear plates go. Any help on the striker plates or the weather stripping?
    TomH33
    Frisco, TX
    TomH33
    Sorry, No help from me on that part... I have not gotten there yet, so when you get an answer, put it here so I will know when I get there. :-)
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
