0
9
Seasoned Citizen
I thought a mid-engine Corvette would be the end of an iconic car. Evidently others feel it too, the new model orders have almost meet the planned production volume. Speculators or mid-engine enthusiasts? Either way, looks like the trans will be made from unobtainium -- good luck finding one you can afford.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
