Looks super ! Thanks for showing the tow bar, something I've been mulling over.
Thanks Art, by the way, your switchback turn signal circuits are working like a charm!
congrats, looks like a nice driver
Started laughing at the switch labels on the dash... then thought, "maybe they're serious?"
Nice pix! I couldn't not notice some details, like the same tow hook as I use, similar strengthening idea so it pulls the car and doesn't bend the 1/2 tube and that hole in the driver's rear splash guard to clear the coolant hose. Mine too makes a bump there but I was able to get away with just that.
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Looking good! Congrats on the first legal drive!
The fourth switch is for future use and isn't connected to anything. I had been watching a lot of fast and furious on tv so I thought I'd have some fun with it. It fooled a few people at the car meet
Thanks! The tow tubes are attached directly to the metal that protrudes under the steering rack so hopefully the 1/2 tubing holding the radiator takes very little load. I couldn't get away with putting that splash guard on without cutting that hole but I did go back and cover it with aluminum duct tape to seal off the dirt.
Thanks! I've gotta check out yours sometime and feel the power!
Drove the 818 to work for the first time today! I couldn't be happier with this thing, it's still needs a lot of body work and a finished interior (and a tune!) but I'm glad I got it on the road and can enjoy it before the winter. 80 mph on the highway felt like nothing, it was very stable. Just cracked 100 miles on the odometer too. Here's the view from the office next to my co-worker's MR2.
Congratulations on the firs commute! It really is a great feeling, isn't it? 'Great to look out and see the results of all the effort, and of course It's hard not to see "more to do's".
That only downside is that at least in my case, work on the car went down significantly as driving went up- and that's OK. Have fun!
818S #332, EZ30R H6, California licensed 01/2019
That's one of the best pictures I've seen in quite a while. Looking out from your office saying, "I built that car!"
The feeling never stops.
Another milestone! Enjoy!
Whoa that is nice!! From the window, I envy you.
I finally had the 818 dyno tuned this past weekend with pretty good results. I had been driving it to work (and breaking in the new motor) the last few months and trying to really take it easy, even took it on a few date nights with the Mrs. I racked up about 800 miles. So on Saturday I took it up to TurboXS to get a speed density tune on an AP. It made 345 hp and 297 ft/lbs at 17 psi of boost. We were having a misfire issue during the runs that we couldn't quite nail down. It was basically causing some bumpiness in the power curve, this can be seen in the videos. We tried replacing the plugs, put in another set of used coils, replaced all of the fuel and added another ground wire to the engine. The misfire got better but didn't go away completely. We sort of ran out of quick ideas and had to call the session short. I'll have to fix the misfire and return to finish the tune. We weren't getting any knock though, so that's good.
I'm going to likely replace the engine wiring harness since it's relatively cheap and my current harness is from 2002. The connectors may be corroded and wiring could be brittle so I'll see if that helps. I could also get a set of performance coils and plugs. The tuner thought it was likely an ignition issue or a bad ground so I'll troubleshoot these things first. My fuel system is not likely causing the issue but that would be the next thing on the list to check. Open to suggestions here.
Now, on to the power. This thing pulls like a monster, it's borderline scary! The 18G turbo spools by about 4k RPM and pulls like a train to red line. It feels like a completely different car than the one I've been driving the last few years. I'm also relieved the engine I put together held up! There's still power on the table since we're only running at 17 psi but it feels plenty fast already.
https://www.youtube.com/watch?v=Z4cXPqSOraw
https://www.youtube.com/watch?v=sZ2QfwUUbk4
Sounds awesome.
Nice, congrats on the new engine build! Next time you're planning to be at TurboXS, send me a note. I'm about 10 minutes from there!
Thanks for the ride the other day, she definitely "gits down"! The misfire should be an "easy" fix and once it's ironed out, she's going to be singing!
