Thread: RLTCS for GTM
    Owensboro, KY
    RLTCS for GTM
    Look here for more info. Most people decide to put a 8 cyl engine in their, roadster, coupe, GTM, or '33 and RaceLogic Traction-Control Systems makes TC systems specifically for 8 cyl engines. The systems range from $1,100 to $1,300:
    - RLTC8ALD (ATC 8 C+LC+DL)
    - RLTC8ALDW (ATC 8 Cyl+LC+DL (TCWSSSET required))
    - RLTC8DIA (ATC 8 Cyl+LC+DL+DA)
    - RLTC8DIAW (ATC 8 Cyl+LC+DL+DA (TCWSSSET required))
    The TCWSSSET are a set of 4 wheel speed senors if your donor didn't have any abs senors or you chose not to include them on your build. There is currently a group-buy going on (see above link) in the 818 sub-forum for a RLTC system. If you think you need to have ordered an 818 to get on of their systems/add-on(s) then you're wrong. It's open to all builders. The above prices are without the discount applied, once applied, it bumps the $1,100 price down to $750 (around due to the always changing exchange rate between pounds and dollars) and the $1,300 price down to $880. If you check on the original thread there's more info (link above). Hope to see more people join!
    FFR '33 #325 built with hazelwwp & FFR 818-S #11 Delivered on July 21, 2013
    Facebook 818-S/R Build Page: https://www.facebook.com/pages/Facto...78385198877613
    Forum 818-S/R Build Thread: http://thefactoryfiveforum.com/showt...-Build-Thread!
    FFR Project 818 Owner's Registry on Google Map
    San Diego
    Thanks for the link. IIRC the GTM folks did one of these in the past and got the really nice systems for $1100. They had the digital adjusters and all that, so it looks like prices have increased a bit.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Owensboro, KY
    Bump
    Owensboro, KY
    Last bump
