6
C.Plavan
Just found out we need to grind, grind, grind... alot... LCA will not rotate- It hits the frame "R" Height on the front.......
During high G cornering there is a lot of force pushing toward the frame, so just grinding for clearance isn't enough. I wonder if they see this on the blue & white car.
