0
0
Many thanks again for the information and suggestions. Much appreciated.
Will try the measurement setup you mention and see what kind of numbers I get but as you state, the frame is jig built so I don't expect anything to be off. I had already measured the position of the LCA mounting brackets and found them all to be exactly the same.
I realize that my wheelbase measurement is not the most reliable. I guess I figured that since the LCAs on the rear end are fixed in length, I would measure from the rear axles forward. I had adjusted the UCA arm lengths on the left side to be exactly the same as on the right and had centered the steering. Obviously, everything was "ballpark" at best. I shouldn't make any assumptions until I get the front end aligned again which I will try to get done next week whenever it stops raining around here.
Have a great weekend,
Ron
Not a waxer
Originally Posted by
SCFFR
....I shouldn't make any assumptions until I get the front end aligned...
Winner, winner chicken dinner
