Results 1 to 15 of 15
Thread: Under fuel tank aluminum plate
    Feb 2013
    Xenia, OH
    Just wanted to post a prop to Tim Whittaker at Kootenai Valley Customs. Just opened my package from him with the under tank plate...super nice piece, and probably the best packaging job you will ever see.
    FFR HR #530
    Junior Member GBodyShop's Avatar
    Got to post some pics. Also how much was the part?
    Feb 2013
    Xenia, OH
    I will get some taken tomorrow. $60 plus shipping.
    FFR HR #530
    The part I produce is actually a two part piece that can be added to a finished car.
    Senior Member hdnik's Avatar
    Welland, Ontario Canada
    I'd second that. WELL WORTH THE MONEY just to keep out the debris and road grime! Excellent fit. Thanks Tim!!
    Factory Five Forums - hdnik
    FFCars - lowntubd
    Build Site/Blog - www.nicks33hotrod.com
    Thanks Nick !!! I'l be developing side pieces to compliment the sill plate as well as an additional piece for the wheel well sealing panel and the door latch cover panel I offer so that the areas are totally sealed off.
    33 Hot Rod #664 BrentM's Avatar
    May 2013
    I made my own, but Tims looks better.
    Sprayed the underside with lizardskin thermal control too.
    very nicely done Brent.
    May 2013
    Thanks Tim, that means alot coming from you.
    Looks like the factory though it was a good idea as well as the door latch cover. Standard parts on the new kits.
    Tim makes some nice stuff, his side pieces are well worth it IMO.
    Thank you sir. More to come. Secondary piece to the door seal, under body seal, electric power brakes, grill surround, "bolt in" IRS, front and rear sway bars and more. The delrin bushings for the front suspension are now available for shipping as well.
    Quote Originally Posted by Tim Whittaker View Post
    Thank you sir. More to come. Secondary piece to the door seal, .
    Tim
    What have you seen to confirm those parts were added by FF and do they have part numbers listed somewhere on them?
    Also
    Not sure what the part is you mentioned above but I have been meaning to ask this. Have you noticed how weak the top of the doors are after
    cutting the holes for the windows? There is very little left of any horiz areas so the two skins are way too pliable. Not sure what kind of part
    could be glassed in on the underside without getting in the way but it really needs something low profile in there to add back some strength.
    Any thoughts?
    Dale
    Hi Dale,
    FFR sent out an update to the manual last month via e mail. The new parts were in that e mail. Just out of curiosity, I called to see what the price was. Same as I have listed for mine.
    I have had several people mention a part for the top of the door as you describe. It could be a part easily made out of metal but I believe most just live with it or add glass from the under side. If I had more requests for a part to fill that need, I would produce something.
    Tim
    May 2013
    They added another one, fuel tank side cover.....
