Page 24 of 28 FirstFirst ... 142223242526 ... LastLast
Results 921 to 960 of 1089
Thread: Metalmaker's build thread begins
  1. #921
    Exeter R.I
    Motors back and I am getting that vroom feeling, hopefully I can drop it in by tues
    Got my break in oil: check
    Torque wrench: check
    All gaskets and torque specs: check
  2. #922
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Nice! So did they fully assemble it for you? I bet you can't wait to have it on the road again.
  3. #923
    Exeter R.I
    I had Russ Johnson in Warwick R.I do the machine work of the bores and the heads. Btw very excellent!!!! machine shop for any engine with 40 years of experience guys. It did not need a line hone, and everthing measured out perfect except one bore. I than had Wicked Innovation in NH assemble to longblock. I have been part of around 4 subaru full rebuilds in the past, from a few years working as a subie tech and just fun builds with friends, but I don't own all the required tools any longer, plus Wicked does such spot on work for me that I decided to have them do it up, they did an excellent job. I just gotta finish up the intake manifold and all the small coolant lines and hook up my perrin Aos, new turbo etc etc etc tune for new injectors etc etc. stickshift84 came up to NH today to talk shop with my friend Jay and Tom at Wicked, we talked shop for like two hours, and would have kept talking but a customer showed up. I am very excited to get it running and break the new mill in. Should make a great powerband and be reliable too.
  4. #924
    Research Calibrator sponaugle's Avatar
    Portland, OR
    Congrats on the motor build.. looks fantastic!
  5. #925
    Chicago, IL
    Excellent Smithers...release the hounds!
    Executive Director
    The Community Garage
  6. #926
    Exeter R.I
    Going hard on it now, almost ready to drop
  7. #927
    Clovis, Ca
    Get that thing in already
    Thanks- Chad
  8. #928
    Exeter R.I
    Got most of it together, just gotta install flywheel, clutch, tranny and run the Pcv setup to the Aos and install header studs and mounts, than check it all over and drop image.jpg
  9. #929
    ...and drive!
  10. #930
    San Jose, CA
    Excellent, great to see it coming back together.
    Feb 2014
    Asheville, NC
    I think we need a start up video!
  12. #932
    Exeter R.I
    Ok I post one if I remember
  13. #933
    Exeter R.I
    Motors in for the second run. I had stickshift84 lend a hand. We tried his method of engine in first alone. It works pretty well, you just gotta get the engine at the right pitch for the tranny to slide in. Either way has it's pros and cons. image.jpgimage.jpgimage.jpg
  14. #934
    Apr 2014
    Its probably here but Im missing it.... What color or coating is that on the intake manifold? Looks really good.
  15. #935
    Exeter R.I
    Good stuff holds up forever, and brushes on. Bakes on @200-300 degrees.
    I also came across chassis savor for the frame that's basically Por 15 but way cheaper.
  16. #936
    Are you also using that KBS on your exhaust pipes and headers?
  17. #937
    You mentioned break-in oil. What are you running for break-in, then what's the plan for later down the road? We're planning to default to T6.
  18. #938
    Cape Cod
    Where is the vid? I'm turning blue holding my breath.
  19. #939
    Exeter R.I
    image.jpgThis is the break in oil, I will run for 350-400 miles drain ( ps it drains very thin, that's normal) and fill with Rotella T synthetic 5w-30 ( best oil for these motors) and you can get it at walmart.
    Also frank my headers are wrapped now.
  20. #940
    Exeter R.I
    Not going to be for awhile, taking my time to get it all nice nice
  21. #941
    Ok so you wrapped but did not ceramic coat under.
  22. #942
    Leesburg, VA
    Sweet beer pong table. We used to have a functional beer pong room in the basement but at the moment it's covered with aluminum sheet metal and car parts scattered everywhere.
  23. #943
    Exeter R.I
    There coated also
  24. #944
    Exeter R.I
    I am a serious beer pong player, strick rules, no blowing or fingering allowed on table!! Lol
  25. #945
    http://m.youtube.com/watch?feature=y...&v=_H2tQeeSltY
    Wipers are working and clear hood, I made them myself like Erik, should be getting plates this week. It's hitting my sticker, so gotta place that higher... Or just take the wiper off once I get plates.
    Metal, I asked a few things about this kit, which helped me understand where on my options list I could use that solution, but I never asked about the parts you used. Are they all from donor or you used something different?
    And I guess you used the 1-arm wiper solution cuz with 2 arms it wouldn't clear the hood?
  26. #946
    Exeter R.I
    It's all from the donor with some use of scrap metal for small brackets, bolts, nuts,and rivets hood support. It works pretty well for something I created in about two hours, I have close up pics posted somewhere. I could have made two wipers work, just more time consuming. If I had more time I could make a kit work with what we have and not have to cut the hood for prob the same price as FFR's.
  27. #947
    Very interesting. So your solution is to slightly change the "natural" curvature of the hood to clear out both OEM arms (if I recall Dan thinks the same). I'll give it a try around June, unless I can spend 40h a week on the car for the next 4-5 months, while still working on my other job 5 days a week.
    Let us know you if decide to build and sell a kit.
    Have a nice game tonight.
  28. #948
    Exeter R.I
    Yeah nice game, the bruins are hurting pretty bad this season.
  29. #949
    Exeter R.I
    So I had some time to mock up my heat shield and put on my turbo blanket after I installed new poly bushings for my lower control arms and installed axles. The poly bushings and full group n mounts should make things very solid. Not really done, I have to trim tower brace slightly and debur some edges. It's ok looking and was just a prototype I won't be using, I am going try something else that's cleaner looking when I trim the tower brace. I am going to wrap my exhaust like my headers and this should all help with heat and look good too.
  30. #950
    Exeter R.I
    Installed and Primed my awic system
    Filled coolant system
    Filled engine break in oil
    Filled gearbox lube
    Primed oil system
    Hooked up post IC temp sensor
    Gotta run base map for new injectors for start up. I had to mount awic slightly different to create better room for my factory bov and my truck brace, but I got it, just gotta make a different rear bracket.
  31. #951
    Filled gearbox lube
    Primed oil system
    Hey Chris,
    Looking good,
    On the bleed valve you put on your AWIC. How thick was the metal there?
    I like the bar you over the AWIC. What is the height of the bar from bottom of shock support brace to the top of the bar you added?
  32. #952
    I second that, I like it too and I too need to know that height (for other purpose).
    tnx
  33. #953
    Cape Cod
    Well done and looks great. Seems like a great solution.
  34. #954
    Exeter R.I
    It's just some stainless bar I had bent into position. It is 8" from bottomimage.jpg
  35. #955
    And the deck lid simply sits on the bar for added strength?
  36. #956
    Exeter R.I
    Yeah, I will be placing a rubber sleve on the bar to reduce friction etc. it also helps with the seem and shape of the truck. You will see when you start getting the panels together. Keep in mind my frame is #13 so revision to the body molds might have been made, so my mods might not be needed. You have to mod as you go
  37. #957
    I have to mod so many things I don't think the body panels will be an exception. But I get it, yes.
    I will most probably have to invert the rear tower brace (cut it and weld it with the transverse bar at the top instead of bottom), and cut and raise the horizontal v-bar over your manifold, I'll try to use those as a support and extend with a bar or something between, if needed. Anyway I'll see when I get there, but I admit when the car is home the project runs MUCH faster! Almost 4h a day in average, now.
    Nothing to do with the above, remind me, you will keep the car white?
  38. #958
    Exeter R.I
    P
    Yeah it's all painted super bright white bro. In paint form with a bright pure white the panels are much brighter and more shinny with the clear than the gelcoat which is almost an off white. So the panels are like ten times brighter in the sun etc. gunmetal was my second choice, but I like white with black/gunmetal accents most.
  39. #959
    Nepa
    What your break in method? On the basic forum if you ask they say ask you engine builder. But I have a brand new stock block still 257 so I don't know who he/she was to ask. Thx
  40. #960
    Exeter R.I
    Quote Originally Posted by Samiam1017 View Post
    Prime oil pressure till oil light goes out or around 15-20 psi on a gauge.
    Make sure engine is running correctly, right tune and no vacuum or other leaks ,
    Use break in oil in my post #939 and drive with it for 50-60 miles and drain
    Fill with a recommend oil, I like Rotella T6
    Keep boost and rev lower for the first 1000 miles with occasional gradual pulls.
