Does anyone have pics of the relief they cut in?
FFR HR #530
Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
My build blog: http://jacks33hotrod.blogspot.com/
Did your kit have the aluminum piece included? I checked my parts list and there is nothing shown. I wonder if the tunnel has been changed, mine is the two piece unit and after shifting the left side I only have about 1/4 inch clearance to the shift fork. Just wondering if I could even get any more foot clearance??
Checking your build thread it looks like you have the two piece trans tunnel like mine. When I called FF tech about the aluminum part not with my kit or shown on the packing slip, they told me it is not needed with this tunnel. I can understand since I was able to move the left side of the tunnel over to within a 1/4 inch of the clutch fork. There really would be no need to add the panel except for possibly some clearance at the top.
looking good! I made mine removable. But most likely will remove batt from underneath if needed.
