I figured I would share this tip if you wanted cockpit control of the supplied brake bias valve. All you need to do is order the Wilwood brake bias adjuster cable (Amazon, Ebay, Summit, Jegs).
Then use a propane torch to heat up the existing black knob on the supplied valve. Get it hot enough to break the bond of the glue. (Try not to get the housing too hot, you do not want to damage any seals).
Then you can screw on the adjusting cable and mount it somewhere in the cockpit. Once you get it in a place you like, make sure to bond the adjuster nut to the valve (I'm thinking red locktite)
Awesome
