Tazio Nuvolari wannabe
Santiago, If only for my enlightenment could you explain (or is there a diagram of) what you meant by "A raised area at the back of the splitter and then down to the floor is a common technique." I was following your comment till I got to that. I guess this has something to do with the splitter and the diffuser being "below", by their material thickness, the level of the chassis/pan?
