Page 2 of 6 FirstFirst 1234 ... LastLast
Results 41 to 80 of 203
Thread: Aluminum Fuel Tank by Boyd Welding
    Encinitas, CA
    Quote Originally Posted by rori View Post
    Thanks. Looks like we need two 3/8NPT with 5/16" hose barb
    Yup, unless you install fancier hose and connectors (braided SS and anodized fittings) like some have done.
    Feb 2013
    Bowling Green OHIO
    Yes, the 818 assembly manual shows to use the Subie filter (p176), however I plan to use something smaller and nicer looking.
    Doesanyone know where this filter is located. My donar was a 2006 wrx wagon and i swear it didnt exist. if i remember correctly all the documentation i had on the maint manual said there was a filter in the tank but i sure would hate to change it.
    05+ only had the in tank filter.
    Leesburg, VA
    Quote Originally Posted by dougkirkbride View Post
    The stock fuel filter is located in the engine bay near the washer fluid tank. It's not in the fuel tank. As others have mentioned, it can be replaced with a better looking aftermarket filter.
    Leesburg, VA
    Interesting, didn't know that! I'm using an 02.
    Senior Member metros's Avatar
    NoVA
    For those interested in finding a nicer looking fuel filter option, take a look at Golan fuel filters. They're pricey up front ($85 IIRC) but they're also serviceable, so you'll get to keep the nice appearance without shelling out that much cash each filter change. They also have options that are E85 capable if anyone is planning a corn build.
    Tucson, AZ
    There's also RobbMc filters. Does anybody have experience with either RobbMc or Golan filters?
    Encinitas, CA
    The RobbMc looks great. I would think the small 10um filter (75GPH) would be perfect to put in the fuel line. Thanks for the info!
    Senior Member AZPete's Avatar
    Thanks, guys. Just ordered the RobbMc 10 micron, up to 75 GPH filter - PN 1072.
    Exeter R.I
    There might be some confusion, the wrx has a filter in the engine bay and on the top fuel pump sock. This is prob were it got messed up.
    Kirkland, WA
    Seems Boyd is using the wrong sender and sender ohm range so the sender that Boyd supplies will not work with the stock Subaru gauge cluster. See http://thefactoryfiveforum.com/showt...nder-ohm-range
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    I would disagree. I bought the 3rd tank made and other than the float was on the wrong side it works perfect with my 2002 WRX cluster. JMTCW.
    Kirkland, WA
    Seems you are not using the optional Centroid sender as Centroid does not use a float, just look at Boyd site "Sending Unit Flange: Yes (0-90 Ohm Sending Unit Optional)" Subaru use 90-0 ohm.
    Tony Nadalin
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    The Boyd provided sender is not a Centroid. It is a basic float type sender. As shipped by Boyd it reads backwards, but 5 minutes with a screwdriver to reverse the float and it's fine.
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Yes, the sender can be reversed by moving the float to the other side.
    Guys, I'm confused about my Boyd tank. It came with the Aeromotive Stealth 340 pump and a 0-90 Ohm sending unit. I've seen the build thread of Wallace18 (post #82) but could someone please post detailed instructions of the required fix - hopefully with before and after photos? Thanks!
    Pete, It is simple. Look at the float. Just move the unit so the wiper reads opposite it is now. I do not have photos. I know you can do it bro. Check with your ohm meter and should be 90-0 when done. It is not rocket science.
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    So 90 is when it's full or when it's empty?
    Kirkland, WA
    Here you go
    Tony Nadalin
    Nov 2012
    Medina, OH
    I need to check mine when I get home to see if the more recent tanks are setup properly. Just in case the photo link goes dead on a later date, I read that as near 0 ohms full and near 90 ohms empty.
    Rich
    Nov 2012
    Medina, OH
    Ah, which reminds me. I remember being confused as to why some had talked about using a 5 ohm resister in series in the circuit to ensure the displayed fuel level was more accurate at empty. After Reading the picture I get it now, adding the two fuel level sensors listed in the manual would be 92-96 (not 90) ohms when empty. So the Boyd sender by itself may not reach a high enough resistance to get the cluster to read fully when the tank is empty. (False sense of security anyone?, lol). Since most fuel gauges can read a few needle widths above full and below empty, I bet there is a sweet spot of say 3 or 4 ohms that gets the gauge to read ON full when full, and ON empty when empty, but with a priority on getting the "empty" reading accurate of course.
    Rich
    Kirkland, WA
    Quote Originally Posted by Goldwing View Post
    I doubt the Boyd sensor has slosh control as that why the Subaru has 2 sensors in series.
    Tony Nadalin
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    It's damped by the electronics in the cluster. When bench testing my cluster it took over 30 seconds for the needle to move from one end to the other when the input was changed from 0 ohms to 90 ohms.
    The reason there are two sensors is because the tank is divided into two compartments.
    From the factory service manual:
    All models are equipped with two fuel level sensors. These sensors are installed in the fuel tank,
    one on the right side and the other on the left side. Two sensors are necessary because the fuel
    tank is divided into main and sub tank compartments.
    Kirkland, WA
    Quote Originally Posted by K3LAG View Post
    The tank is not physically divided into to 2 separate tanks, it is compartmented to reduce slosh and the summed sensors are averaged. if there are senders at both ends, ideally an increase in ohms at one end as it goes more empty will be negated by a decrease in ohms at the other end as it goes more full, with the sum of the two approximately unchanged despite the tilt.
    Tony Nadalin
    Geez, you say it's simple, but I read the resistance before I did anything as 9.1 Ohms - see photo #1. Is that close enough to zero?
    Then, I removed the sender and it reads 7.8 Ohms. Photo #2.
    I loosened the pivot screw and reinstalled the float on the other side so it matches the photo in Wallace18's build thread, post #82 - see photo #3.
    The resistance was 94 Ohms in the empty position and 7.8 in the full position - not 90 - 0, but okay? However, when I went to remount the sender into the Boyd tank the float rod hits the side wall and round top mount with 5 holes will only go one way. Should I also remount the sender mechanism 180 degrees on the top circle mount? Or, move the lower mechanism to the other side of the vertical piece? This may be handy for others following, also.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I loosened the nuts and rotated mine 180 degrees.
    Huntsville, Al
    x2 did the same thing on mine..works great!
    Massachusetts
    I just installed my Boyd Welding tank and have a question on the fuel level sender. Some people are saying I have to reverse the lever on the sending unit. Does anybody have before and after pics? Also what should it read for resistance before and after?
    Dave, that confused me also but I eventually got it right, with help from others. See Post #42 in the Tips thread:
    http://thefactoryfiveforum.com/showt...dd-yours/page2
    Massachusetts
    OK I just read the posts above and found the answer. I will do a resistance test after lunch.
    Massachusetts
    Massachusetts
    I tested it before I changed anything. 7.8ohm empty and 94.9ohm full. Then I reversed the float like the pics and swiveled the top round piece that screws to the tank. Now I get about 1.4ohm no mater what I do. Did I break the variable resister or the white wire? Dave
    Massachusetts
    OK Today was a better day. I loosened the nuts on the center post of fuel level sensor and then re-tightened. Now the resistor seems to be working so I installed it in the Boyd tank. Can't test anything further until I get wiring, fuel lines and cooling system in. Thanks for the help.
    Frankfort, IL
    Reviving an old thread - how are people enjoying their Boyd tanks? Have there been any revisions since V1? Any revival in the interest to make a larger tank filling the entire space, rather than leaving a gap to the firewall or having to re-bend the firewall?
    I have reached the point of fed up with my leaking original tank and just priced out the new one from FFR at nearly the same price as the Boyd tank. Before I plop down over $600 on the new Boyd tank though, I'd like to hear how it's working out for people.
    Administrator
    Enterprise Alabama
    They work great, was a slight revision but they are really good.
    Quote Originally Posted by billjr212 View Post
    Boyd tank is well worth the money. I used 1 in my 33 and 1 in my 818.
    Senior Member D Clary's Avatar
    Santa Rosa CA
    Does anyone have fuel starvation when cornering? How much usable fuel is in the tank?
    Suisun City, CA
    Quote Originally Posted by D Clary View Post
    Yes, on right hand turns and < 25% fuel.
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
    Santa Rosa CA
    That would reduce the usable fuel to around 7 gallons.
    Suisun City, CA
    Perhaps on track, yes. Around town, it's fine. I think I've had it all the way down to like 2 gallons or so? Even then, I didn't notice any sputtering with normal driving.
    Finished: NEVER!
