michael everson
I have one here now that I thought about doubling the floor with another piece of aluminum. That or put some small aluminum angle pieces riveted to the underside of the trunk floor. You can buy angle 1/8 thick as small as 1/2 inch.
Thanks Mike, on thought i had was to work on the inside and see if i could get a hat channel maybe 3/8 high. make 3 rows from front to back and build up floor possible use 1/2 mdf on top side and insulate between for noise.
Nick Sebastian - 33 Hot Rod #495
Factory Five Forums - hdnik
FFCars - lowntubd
Build Site/Blog -
www.nicks33hotrod.com
