0
0
Replacment recommendations for the stock G50/20 clutch
Hi guys,
I was hoping someone could suggest some clutch kits for my transaxle. I dont know whats going on with it, but it seems to be slipping in any gear but only at high revs. I did read on the forums that if you over extend the clutch that this can happen and when it does, your clutch is basically scrap.
So here are my GTM specs:
Stock G50/20
Stock 2003 LS1 from a C5
The car is a little heavier though, at 1150kg..
Do i have to get a higher spec clutch? Or should i just get a Porsche stock replacement considering my engine isnt pushing higher numbers?
Thanks, Tom!
- You may not post replies
- You may not edit your posts
Forum Rules
